whenever I mount anything to a virtual drive, it won't let me play it. For example, I mounted empire earth II and whenever I double click on the drive under my computer, it brings up the autorun screen, but whenever I click play, it tries to access my actual cd drive and it says "Wrong disk inserted". It's like that with anything I mount. Any ideas?
Wrong Disk Inserted
I have clone DVDs I made with Alcahol 120% for The Movies and also for Civ IV and I get the same thing. It works if I use SD4hide and S7stop respectively but I thougth the whole reason for this version was to make it so the "no cd" cracks wouldn't be necessary
same prob
hey i just got daemon tools 4 and when i mount any securom 7 or safedsic 4 image they tel me the same error insert the correct cd
so isnt it supposed that dt 4 support this kind of protection or should i use other affilities with it??
i dont want my original cd to be scratched
Yossef A. Ben Mikhail
MCSA MCDST
any mevin ivrit.
Doesn't anyone read the realese notes?Originally Posted by yacboshey i just got daemon tools 4 and when i mount any securom 7 or safedsic 4 image they tel me the same error insert the correct cd
You will need to unplug your IDE drives, either with SFN or manually.Last edited by Methadon; 15.11.2005, 16:53.
dude wake up you said it yourself SFN is for star force portected games not securom 7 and safedisc 4Originally Posted by MethadonDoesn't anyone read the realese notes?
You will need to unplug your IDE drives, either with SFN or manually.Yossef A. Ben Mikhail
MCSA MCDST
any mevin ivrit.
Right sfn is also used for SF Games.
But DTv4 is a new program so sr7stop doesn't work with it.
So you've to deactivare your ide-drives for example with sfn if you want to play some sr7 games.
This is because of the scsi blacklisting, all scsi controllers are blacklisted, if they are real, too.
So if there isn't any ide drive if you want to play and there's only the one scsi drive, the game will accept it.
DTv4 isn't blacklisted, yet.
Ehhh, when did I say that SFN is only for starforce protected games and not sercurom and safedisc?Originally Posted by yacbosdude wake up you said it yourself SFN is for star force portected games not securom 7 and safedisc 4
Stupiest thing I ever heard.
CD's are quite durable.....unless the production value has seriously decreased in recent time...I wouldn't worry about your CD's getting scratched. I've never lost a CD from damage from being in a drive too much.Originally Posted by yacbosi dont want my original cd to be scratched
Granted when the slip out of my hand, fall to the floor, and I roll over them with a chair is a different matter....
I know Electronics Boutique is pushing their 'CD/DVD Insurance' for your CD's and DVD's getting damaged by being in the drive too much....don't buy into that....
Ok just to clarify SATA is an interface for IDE equipment, there not alternatives to each other.Originally Posted by ryonavinI have all serial ATA drives no IDE whatsoever and I still get the problem
ATA: Advanced Technology Attachment
This is the standard connection and uses the Ribbon cables we proberbly all know too well
SATA: Serial Advanced Technology Attachment
The newest interface type, its faster than ATA and theres even a SATA2 which is faster again. uses the lovely thin cables, with the nice smaller connector to the huge strip!
IDE: Integrated Drive Electronics
This is any integrated Drive, (Hard disk/Cd rom/DVD rom ect..) An IDE device is connected either by SATA connections or ATA connections. You have a SATA IDE drive, its still an IDE drive.
Oh and just for reference:
SCSI: Small Computer System Interface
SCSI (usually pernounced 'Scuzzy') is different as it operates on a different BUS (The SCSI bus compared to the IDE Bus) and doesn't require the Processor to operate the SCSI bus controller and two SCSi hard disks can operate at the same time, IDE drives having to take turns. (Bus is the thing that links your HD's to the main memory)
But in saying that you could go into your bios and make sure your Drive Channels are set to "SATA only" and not SATA/ATA. Maybe... its ATA thats stopping it, tho i doubt it...
He's right. SATA is basically just a newer version of IDE, which has replaced PATA IDE for the following reasons:Originally Posted by TigRonOk just to clarify SATA is an interface for IDE equipment, there not alternatives to each other.
PATA has a maximum interface burst bandwidth of 133 MB/s.
It also has a narrower interface cable. So there's probably more room in the PC case.
SATA has 150 MB/s for the maximum interface burst bandwidth. SATA II (I believe that's what it's called, AFAIK) probably has more.
