SC:CT with v4
  • SC:CT with v4
    i've installed the new v4, and i hate to be a noob, but what is the process by which sc:ct is run? is it necessary to have a 1:1 copy, or would a miniimage suffice? Will I still have to disable nodes with starfuxr?
    sorry to be a douche, i just cant get it to work.
    Imperial Glory? or Metric Dishonour?
    SC:CT (at least the german DVD version) is protected with StarForce 3.4 which doesn't work with a Mini Image (as far as I know), and which needs all ATAPI drives (= optical IDE drives) to be disabled. I recommend StarForce Nightmare for that, just use the "Disable/Enable CD" functions, that works just fine with Trackmania Sunrise (which is protected with SF3.4 too).
