Version 4 is exactly what I thought it would be and exactly what the dev team said it would be.
All my StarForce protected clones work great with DT4 and SFNightmare. It is SO much better than using the unstable SFcure.
SafeDisc4 and Securom 7 work also just fine but w/ SFNightmare instaed of SD4 Hide and SR7.Stop.
What more did anyone expect? It was said long ago that the IDE plugin would come after the release of Version 4.. It is common knowledge that StarForce, Safedisc, and Securom Blacklist ALL SCSI drives. So untill the release of the IDE plugin we will have to use SFNightmare, no surprises there.
As for not being able to use SD4 Hide and SR7.Stop, they were designed for Alcohol 120% Build 3105 and DT 3.47 and prior versions. It was never stated that SD4 Hide and SR7.Stop would work with DT4.
So I will happily use SFNightmare for a little while untill the IDE plugin is released.
And I have to use Alcohol with Securom7 pretected backups, because SF7stop doen't work with DT4 anymore...
