Splinter Cell don't work with DT v4! What I can do? I should install a patch or something? If somebody play the game with DT v4 , tell me how you do.
Splinter Cell 3 don't work with DT 4
Strange problem because of Starforce
I have got 2 games with StarForce: GT Legends (3.6) and
SCCT (3.4).
After installed the first game SCCT (of course, with DTv4) and unplugged my IDE writer I tried it: SF say "Disk Key don't correspond to the disc in drive...."
I used snake's image because the mini-images from Copybase.ch didn't work, because DT4 said: The file is unaccessable.
With SFNightmare (disable node and ch2): no success,
SFCure: no success.
Then I try my luck, so I install my next game - GT Legens - and without SFNightmare and SFCure (or anything else) it is working perfectly!
My PC is Alcohol-free,
so, I think the problem is with the DPM in the SCCT image.
If somebody have a good solution, please write!
