I have upgraded all of my systems to Daemon Tools 4.0 hoping that the need to use SR7.Stop and Sd4hide would cease. Sd4hide still works as do the games that require it, However now I can not play any securerom 7 games without using the original disc because SR7.Stop does not work with DT4. Does anyone have any ideas on what to do to solve this problem. Is there going to be a new version of SR7.Stop thats DT4 compatable or is daemontools going to get a small update soon making it not necessary?
SR7.Stop does not work with DT4.0
You can play securom games by deactivating your ide drives in device manager.
Now you only have to mount the image and start the game. That's because of the scsi blacklisting, but dt 4 isn't blacklisted, yet.
Yup, Methadon is correct, and some will refuse to run even if just disabled in SFN, this is because some newer ones are able to detect drives that are pysically connected regardless if they are enabled or not. Even when disabled, they are still visible to the Windows API, so they are visible to anything that can query them.Originally Posted by MethadonFor starforce games you will have to unplugg your IDE drives, either with SFN or manually.No, you cannot have my signature, unless you pay me. I am famous you know.
windows API
Dllfile, not that it makes any difference but its a driver level thing not Windows API or SPTI
hello the dude is speakin about matrix the path of neo wich means securom 7 not starforce at all and yes i got the same problem and i must use sr7stop to play itYossef A. Ben Mikhail
MCSA MCDST
any mevin ivrit.
We are talking about securerom 7 games not starforce, and it worked just fine with the prior release of DaemonTools. The only problem now is that SR7.Stop cant hide any of my virtual drives as it does not see them anymore. I am considering rolling back to the old version until Daemon Tools is updated or a new version of SR7.Stop releases that supports DT4
StarForce, SecuROM... doesn't matter, they all block SCSI drives if optical IDE drives are found so you need to hide your optical IDE drives.
You can either do that with StarForce Nightmare or by unplugging the power cables from your CD/DVD drives."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
well it seems that Methadon is in love with starforce that he thinks all protections are starforce and any protection needs to disable the ide
DUDE you are in the real world the matrix is booom wake up and read the whole threads not all games are starforce
and Nestan for me i removed alcohol 120 and now sr7stop works fine with meYossef A. Ben Mikhail
MCSA MCDST
any mevin ivrit.
I'm quoting myself: "For starforce games you will have to unplugg your IDE drives, either with SFN or manually".Originally Posted by yacboswell it seems that Methadon is in love with starforce that he thinks all protections are starforce and any protection needs to disable the ide
I thought Path of Neo was a starforce game, I know i made a mistake. But why should that mean that I am in love with starforce? And why should that mean that I think that every game has starforce protection?
With v4 it's a must to unplug your IDE drives with the games that has a protection that has blacklisted SCSI drives.
And it's not only starforce that have blacklisted SCSI drives.
