Cant play Worms 4 whit DT4, i try and try and nothing ....
  • Cant play Worms 4 whit DT4, i try and try and nothing ....
    ok i read in some post i have to unplug the ide CD/DVD-Burner so i did and turn on my pc and mount the image but nothing happend itґs request the CD i sued too the Starforce Nightmare 1.12and nothing , any idea ?, something i have to change in the registry or something ?
    i mount the image in ISO format
    You'll need a good image to play from it. ISO doesn't work. Please create a new image from your original CD with Alcohol 120% and try again.
      Heey,
      i got it booting ( the game ), with the method using SFN, SFAFSB, and dt4, but it gives a error message that an internal error occured when trying to acces one of the applications libraries .. Anyone familiar with it ?
      thx for your time
        Make sure you have installed it correctly and there are no regkey denys.
        So for me it works with unpluging my drive and use dtv4 and a
        good image with dpm and rmps emu.
        That's all.
