I have 2 near identical systems, on one I burned a copy of X3 using alcohol the other system I have never installed alcohol.
I mounted the image on both machines with DT4, the one that has never had Alcohol installed worked first time the one with Alcohol didnt. I tried uninstalling Alcohol and everything associated with it but X3 still wont work on this system.
What is it that Alcohol does to your system or what file does it leave behind that alerts starforce to Alcohols presence?
