Splinter Cell don't work with DT v4. I should install a patch or something else to work. Tell me what I can do, ,please...
Splinter Cell 3 don't work with DT 4
It's not absurd, that is what you have to do. Either you do it with SFN or manually.
It's because almost every copy protection has blacklisted SCSI drives, doesn't mather if they real or not.
When a optical IDE drive is detected, the copy protection doesn't accept SCSI drives.Last edited by Methadon; 16.11.2005, 15:32.
Obviously you've never heard of StarForce. Want to know what's really absurd? Not being able to play a game from a SCSI drive if you have an ATAPI (IDE optical) drive in your machine. THAT is why you have to unplug your IDE disc drives prior to mounting and playing a game that uses StarForce, such as SC:CT. There's also another method that uses SFCure and SFNightmare to disable your CD/DVD IDE drives, but advanced versions of StarForce can still detect your drives if the parallel ribbon cable is still plugged in. DT4 w/ the IDE jammer and DT4 Pro should make this much easier, specifically no physical unplugging.Originally Posted by SlimShadyThat's the most absurd solution I've ever heard.
Arb
SC-CT does work, ive played it first time ever without disc, you need make alcohol image (im told others work but i tell you why i used this method in minute) then you can download a new .mds and this mounts in daemon tools V4 instead of .mds you made along with your .mdf (obv your gonna have big image on hdd alltime but no disc in rom tray, you will still need to dissable roms, i do it by setting bios to turn of eide as my hdd is sata, i dont know if device manager is enough for this older game, i mostly hang pc using starforcefucker/nightmare so i dont like them.
I also got Chrome to go futher than before passing disk test but it stays at black screen with little whitr hand cursor.
Trackmania Sunrise now wroks with roms dissables and image in DTv4, before i had to dissble roms and use a mix of 2 tools to get it to run without disk, and bonus is the new FREE addon out other day you can download and install if you have Trackmania Sunrise installed, (http://www.gamershell.com/news/26278.html)
Don't you like it Methadon when people with one post start from the first one to be smarter than the rest? It seems that the search function on this forum is hidden somewhere very well.
Peace!
p.s. some dude pissed me off because of the same thing. If my post has nothing to do with the thread I demand to be erased. SlimShady be evasive!Last edited by kukubau; 16.11.2005, 15:44.So, mother goose has been messin' around in your egg salad, huh kid?
Patch it! it works, tested up to latest 1.05Originally Posted by al1ukI've managed to get it working. Unplug your drives, and enable all emulations. Im using SCCT without the patches, incase it don't work afterwards.
Yup. Unplug the power cables (red-black-black-yellow), they're easier to remove.Originally Posted by aitzazWell i am a newbie here i dont know what u ppl have been saying all the from the start of this topic.I want to ask u in order to run this game i will need to pull out the cables from my cd and combo drive"I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
