Hello all,
this is how I defeated StarForce.
As you know, the current StarForce releases check you IDE channels for Optical drives and refuse to launch from SCSI/DT4 if one is detected.
However there is an easy and cheap solution to this problem:
- get an extra IDE controller that is compatible with ATAPI drives
- plug all your optical drives in there
- launch the image via daemon tools v4
The best thing is: you don't need to disable anything! You ONLY need daemon tools, that's it. No channel disabling, no cable disconnecting.
I recommend an ATA133 raid controller using SI0680A because it will still have some potential use if there's another method around Starforce. Plus those babys are just roughly 20 or 20$ shipped.
Here's a list of eBay auctions for those cards:
US http://cgi.ebay.com/ws/eBayISAPI.dll...tem=8723150538
DE http://cgi.ebay.de/ws/eBayISAPI.dll?...tem=8721713305
UK http://cgi.ebay.co.uk/ws/eBayISAPI.d...tem=6822575483
They are cheap everywhere and it really is the best solution I've seen so far. Should work with older controllers as well as long as they support ATAPI aka optical drives.
