why sd4hide is still needed??
    Originally Posted by Sabrehawk
    And again someone that does not understand that he
    must DISCONNECT his optical drives from power and
    play this game using the image file only. Simply disabling
    the drive via bios or software doesnt help and especially not if you disable it with the WRONG tool. SFNightmare is for
    Starforce and not for SAFEDISC. You must use SD4HIDE.EXE. Safedisc doesnt care a rats ass if you disable
    node and cd using sfnightmare.
    If I run UFO:AS (SF 3.6) and run SFcure I can either use SFNightmare + Disable Node or use SD4Hide.
    If I run NFS:MW (SD4) I can either use SFNightmare + Disable Node or use SD4Hide.
    Both games work both ways for me.
