Would like some advice on how to get things properly working!
I would like some opinions on what i could do/check to make sure i can get DT4 to work without sd4hider.
Earlier i got starforce 3.6.10.03 working no problem with sfcure etc with sfnightmare...without physical disabling.
i would like to run safedisc4 without sd4hider.
what did i do:
-removed sfcure driver and registry entries
-removed old deamon tools registry entries that i could find
(still some other scsi miniport drivers there, dont dare delete all in registry)
-removes old daemon-tools drivers system32/drivers
-uninstalled alchohol120%, removed drives in system32/drivers
i run a dutch system: this is my device manager
jpeg screencapture of it)
amd 3500+ (64) with winxp sp2
2xsata, officially via raid setup, but both seperated there, not linked raid (yes, thats possible on the asus mobo)
plextor dvdr as only cdrom drive
the virtual disk device=winternals admin device
Any opinions on what could cause safedisc4 to need sd4hider still at this point with dt4?
would appreciate feedback there!
what did i do:
jpeg screencapture of it)amd 3500+ (64) with winxp sp2
