Tells me to insert correct cd
  • Tells me to insert correct cd
    I installed ultimate spiderman perfectly from an image but when i click play it tells me it cannot locate the cd rom. this was in the manual but nothing in there worked.
    OK! Spiderman is Safedisk 4 protected, if you use DT v4 you need to disable your ide drives with Starforce Nightmare or in the Device manager or you could use Safedisk 4 hide.
    http://cdmediaworld.com/hardware/cdrom/cd_utils_8.shtml
