WHen i execute SR7stop i press hide while the crime life image is mounted in daemon tools but it says theres nothing to hide.
Can anyone explain how this sr7stop tool works.
Cheers
TNTIcemanTNT
If you use DTv4 it's normal, because DTv4 isn't supported by SR7stop. You've to use SD4Hider, SFN (disable cd, node), or new tools like SD4start, SD4 Blocker or Securom 7 burner loader for Safedisk 4 and Securom 7.
Or you could try to disable the ide drives in Device manager.
That's because of SCSI Blacklisting of the copy protections. All scsi controllers are blacklisted and DTv4 use for his Virtual Drive an SCSI Controller.
This problem will be solved by the IDE-Jammer which will be released soon.
