Hi to all,
This is how I beat SF3 (all versions) without disconnecting IDE cables.
Most important of all is when buying new configuration not to buy Parallel ATA hard drives. Buy SATA! They are faster then PATA drives and almost the same price.
In that case on your PATA controller you'll have only optical IDE drives.
Now, all what you have to do after mounting image with DT4 is to go to Windows device manager, find parallel ATA controller and disble it. After playing game if you need optical drives, go again to device manager and enable PATA controller.
I think it's worth spent few bucks more to buy SATA hard drives and f**k off SF3 with just a few clicks than opening computer case and constant unplugging-plugging of IDE cables and risking to crack something.
So, the trick is not to disable optical drives only, but the whole controller.
