Nfs Mw
  • Nfs Mw
    I want to find out what kind of software people who 'magically' can get this game to work are running.
    This is a poll for people who have tried to run this game, sucessfully or unsucessfully, while using or not using AntiBlaxx antiblacklisting software.
    Imperial Glory? or Metric Dishonour?
    I can play NFS:MW using one of the following ways:
    • Disable CD with SFN
    • Disabling my optical drives in Device Manager
    It probably works with SafeDisc 4 Hider as well.
    AntiBlaxx was for un-blacklisting Daemon Tools v3.47, DTv4 hasn't been blacklisted by any copy protection yet.
      I can play it without having to use any antiblacklisting tools and without having to unplug my optical IDE drives.
        Do you by any chance have an nForce chipset?
          I got it working on one pc with just DT4 and with another just using DT4 + sd4hide.
          It ain't starforce protected as far as I know.
            Hi,
            for my part, i can make this game running simply by using deamon-tools V4 without any option ON ( juste the image mounting fonction )and the use of DVD REGION free launched.
            Boths make it runs nice. If DVD region Free off, the game crash due to a temp file.
            Hope it helps,
            Weeby.
              Yeah I use nforce also and right after I installed it it worked perfectly, however for a friend of mine it doesn't work at all even after unpluging the drives, the only method he found is to disable the network card and strangely it worked.
              The last of the best, the death of the rest. Hitman Forever...
                Yes, a nForce3 chipset, does it has anything to do with it?
                  still in the guessing stage
                  I think everyone is still at the guessing stage. I propose its any chipset whose name has the letter 'n' in it
                    Same here works great
                    • #11
                      I need to disable or unplug my IDE drives for this to work.
                      I am using an nForce 4 board.
                      • #12
                        unplug your ide drives from power+cable - mount - run - play
                        if it doesnt work try to remove alcohol etc, or use a proper image
                        • #13
                          nfsmw works fine for with dt4 with no additional software, i have nforce2 motherboard and my dvd drive that i have is on an external card at the moment.
                          • #14
                            nForce
                            Weird kitna. We might have to start asking people their nForce IDE/Storage Controller Driver Dates/Driver Versions.
                            • #15
                              use SFAFSB and SFNightmare, and disable node for me it was
                              thats all
