Ok, here's my situation. I have 4 optical drives, 2 connected to an IDE controller and the other 2 connected to the mainboard controller. I have also made an image with RMPS of my SCCT DVD, of course. I use StarForce Nightmare for disabling the 2 drives connected to the mainboard controller, for the other 2 I have to physically unplug them (I have done it). The problem is, when I get ALL the drives disabled - and the Alcohol/Daemon Tools V4 virtual drive is the only one remaining - and try to play the game, it tells me to insert the disk in another drive. What drive??, I ask myself, since Windows must see that there are no drives connected except for the virtual one.
So there are 2 possible solutions: 1) SF sees the drives disabled with SFN, or 2) SF sees the virtual drive and blacklists it.
In case 1, I have tried to physically unplug ALL optical drives, but Windows refuses to run because, without the drives, there are my 2 hard disks, which are Primary Master and Secondary Slave (I think the problem is that there must not be a slave device without a master one, am I right?).
In case 2, I have installed sfcure and Win2k3 node disabler, but StarForce still asks me to insert the DVD in another drive. But Win2k3 N.D. requires the user to specify the service name to disable - and the standard for Daemon Tools is d347bus. But I am using daemon tools V4, so I think Win2k3 node disabler is not disabling the right services!
In conclusion: what's the service/device name for DT4 ? How can I get the game to work ?
