Hi everyone...bad news
I have to inform the forum of two things that i have discovered recently.
Using a my computer with Alcohol 120% I have used High DPM precision settings and made a working backup of the game Trackmania Sunrise Extreme with DTools v4 (ide disconnected)......
The game plays well...............I then turned to make another image of Panzers 2 which uses starforce 3.47.77...normally no problem.......................
To my surprise Alcohol 120% was now locked to DPM Precision 'Normal' settings...these arn't good enough to make working images....'High' DPM Precision settings are required.
To my greater surprise this new configuration seems to be permanent, ive tried everything bar reinstalling windows which would obviously fix the problem as long as I dont reinstall the new starforce drivers on my machine used for backing up.
Has anyone else found a way around this horror?
