Okay, I have purchased the newest game from EA Games : NFS Most wanted. The thing is I do not like to insert the CD everytime I play the game. Mmmm... It seems SafeDisk 4.6 has some power over CD/DVD immulating software. Pls help me to create an exact 1:1 copy of the CD/Game. ( I believe as a rightful owner I can make a single backup copy of the CD? )
Nfs Mw
So you need to make an Image using Alcohol 120%.
It's on CD?
So you've to create an Image with Alcohol and use the Safedisk 2/3 profile and enable additionaly the Subchannel option.
Choose the mds-mdf file type and create the Image.
Now you could mount the image with DAEMON-Tools 4 or Alcohol and use SD4Hide for antiblacklisting or disable your ide-drives with Starforce Nightmare. Now you can play the game with the cd mounted in the virtual drive.
If you would burn it on a cd use the assistant of Alcohol
to burn it, also use the safedisk 2/3 profile.
If you play with the burned cd you also need to use SD4Hide becuse DT and Alcohol are installed and the Copyprotection (Safedsik 4.6) blacklists this tools or uninstall Alcohol and DT.
The tools:
www.alcohol-software.com <-trial version
http://cdmediaworld.com/hardware/cdrom/cd_utils_8.shtml
