Peter jackson's King kong
  • Peter jackson's King kong
    Hello
    I need help with my King kong
    It says : ''please insert the cd into another drive''
    IF somebody could give me a detailed describtion of how i could get the game working
    Help
    The only way to get this game working is by unplugging your IDE optical drives.
    Tools like SFN don't work anymore with this SF version.
      It's so eadsy
      Just power off the cd drive
      King is working
      used DT4 en powerd off the cd drive , Trackmania sunrise is working also.
      greetzzzzzzzzzzzzz
        How do u
        how do u power of you're cd drive with dt4?
          You can't do it with v4 yet, but they are working on a IDE jammer.
          You will have to unplug it physically with this version of Starforce.
            ohhhh thank you
            now its all clear
            got to wait
            Go daemon Go
              yes, king kong has starforce 3.6.10.06
              this version will not work with software emulation at this time..
              shut down pc, open pc casing, remove power cable from dvdrom drive (or ALL dvd/cd drives that are on IDE connectors)
              restart pc, sometimes you need to change the boot sequence to start from Harddisk in bios settings!
              chrome specforce has 3.6.10.03, that one actually did work with sfcure, sfn (disable noce, disable cd, disable secunday master (or what ide port you got your cd/dvd drives on).
              But was last one to work for me (i used sfcure x64 one there)
