i used to play ufo aftershock from an dt4 mounted iso and everything worked just fine.
but after installing the first offical patch, starforce wont let me start the game again...so i have unistalled the game, reinstall it and again everything was back to normal...
the problems is that i think the patch implements a newer starforce version, one that bypasses even dt4 emulation
(i don't have any optical drive connected to my comp, also tried using sfcure, sfnightmare, etc...everything works ok until i install the patch)
help would be appreciated
