Problems Installing Black and White 2 from an image...
  • Problems Installing Black and White 2 from an image...
    The image mounts correctly and I'm able to run the installer, but everytime part way through the installation I receive an error telling me the installation could not be completed due to an error ...
    This happens when I try to install fable from an image aswell. I'm a bit new to the whole virtual drive thing, so would someone care to enlighten me about what the possible problem could be?
    Usually an image should work just as the original. What exact error message do you get? How did you create the images?
