Need For Speed Most Wanted problem!
  • #61
    Cd imaged
    I am using 4 cd mdf images created in Alcohol 120 %
    • #62
      What kind of cd-copy programs do you ahve installedon your laptop? Do you (ever) have CloneCD installed? Uninstall it.
      The Message which you get on the other pc, when you don't use SD4Hide, is the right message you always get when you didn't use SD4Hide or another antiblacklisting program.
      • #63
        Thank you
        Yes i had clone cd installed, removed it and it now works perfectly, thank you very much
        • #64
          CloneCD is blacklisted very hard. I had a friend who had uninstalled CloneCD and there were only some registry keys left by the uninstallation and FIFA 06 didn't start. I found these leftovers, deleted them and then it works.
          • #65
            OK OK OK >.... i got lazy and didnt read this whole form.. but i think i got the answer to all you NFSMW questions!!! ok, it seems you need to rename a file in the device manger!!..
            ok, here is how u do it.
            click start menu.
            click on RUN
            type "regedit"
            your registy editor comes up..
            goto Hkey_local_machine\Hardware\devicemap\Scsi
            rename the foldor scsi to scsi1
            this should fix problems!!
            i think u have to do this everytime u wanna play, but im not sure.. it works for me, and sorry if anyone else posted this, becuase i didnt see it, im just tell u what works for me!!!
            • #66
              speed.exe has encountered a problem and it's your guess
              Hello! This is me regging up and bumping in on an ancient thread as I have at least one solution to this problem nobody has suggested yet.. in the whole world so far as I can tell.. I have been Googling and forum diving for weeks to find an answer to this crash and finally figured it out via trial and error.
              The "speed.exe has encountered a problem and needs to close" message was IN MY CASE a "Power Mizer" power-saving feature related to my LCD display panel (on a GeForce 7900 GTX 512, in an XPS M1710).
              The screen refresh rate was forcibly reduced to 50Hz when I selected the eco-friendly mode. This causes NFSU1/U2/MW to crash before the load screens can start (VERY easy to reproduce and repair the crash now). It also causes you to pull out hair and scream (if you forget what you did).
              Apparently energy-saving features override the card's ability to change refresh rates on the fly so the card stays in 50Hz FULL STOP PERIOD. Unfortunately replacing graphics drivers maintained my problematic settings, and resetting drivers to default didn't affect the power saving mode. HMMMMM.
              I was going crazy, I even tried some "less savory" methods on my legit copies to get them to work again.. no useful help from EA, no luck on the dark side either.. Tried every utility out there.. WEEKS I went without NFSMW.. Just got down and started checking every box in the world and found it, finally. So yeah this is my celebratory post I guess. Please enjoy.
              Hope someone gets their game running again!
              R3
              • #67
                thanks
                thanks for giving safedisk blocker
                • #68
                  Need for speed underground and most wanted
                  For some reason i can't install both need for speed underground and need for speed most wanted on my computer... when one of them is installed and i go to install the other one it says play and uninstall and if you click on either it is for the already installed game...
                  if anyone can help that would be really appreciated
                  • #69
                    I can confirm that bug, as weird as it sounds. Most Wanted appears to think it's already installed if Underground is installed on the system. Unfortunately I don't know how to solve this, I just uninstalled Underground when I had that problem.
                    Please contact EA's official support for this, as it certainly isn't a problem with Daemon Tools.
                    • #70
                      Somebody plz help!!!!
                      System Information
                      Time of this report: 3/20/2008, 23:23:07
                      Machine name: HELL-ASIR0O4HDC
                      Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
                      Language: English (Regional Setting: English)
                      System Manufacturer: VIA
                      System Model: K7VT4
                      BIOS: Default System BIOS
                      Processor: AMD Duron(tm) , MMX, 3DNow, ~1.6GHz
                      Memory: 448MB RAM
                      Page File: 353MB used, 960MB available
                      Windows Dir: C:\WINDOWS
                      DirectX Version: DirectX 9.0c (4.09.0000.0904)
                      DX Setup Parameters: Not found
                      DxDiag Version: 5.03.2600.2180 32bit Unicode
                      Card name: VIA/S3G UniChrome IGP
                      Manufacturer: VIA/S3G
                      Chip type: VIA/S3G UniChrome IGP
                      DAC type: Internal
                      Device Key: Enum\PCI\VEN_1106&DEV_7205&SUBSYS_72051849&REV_01
                      Display Memory: 64.0 MB
                      Current Mode: 1024 x 768 (32 bit) (60Hz)
                      Monitor: Plug and Play Monitor
                      Monitor Max Res:
                      Driver Name: vtdisp.dll
                      Driver Version: 6.14.0010.0212 (English)
                      DDI Version: 9 (or higher)
                      Driver Attributes: Final Retail
                      Driver Date/Size: 3/8/2005 11:50:06, 3453824 bytes
                      WHQL Logo'd: Yes
                      WHQL Date Stamp: n/a
                      VDD: n/a
                      Mini VDD: vtmini.sys
                      Mini VDD Date: 3/8/2005 11:50:16, 172544 bytes
                      Device Identifier: {D7B71FE6-3145-11CF-2D7B-0F52A0C2CB35}
                      Vendor ID: 0x1106
                      Device ID: 0x7205
                      SubSys ID: 0x72051849
                      Revision ID: 0x0001
                      Revision ID: 0x0001
                      Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
                      Deinterlace Caps: n/a
                      Registry: OK
                      DDraw Status: Enabled
                      D3D Status: Enabled
                      AGP Status: Enabled
                      DDraw Test Result: Not run
                      D3D7 Test Result: Not run
                      D3D8 Test Result: Not run
                      D3D9 Test Result: Not run
                      This is my pc's configuration...when I play nfs most wanted on it, it runs quite well but after 15-20 minutes it crashes and displays a message saying speed.exe has encountered a problem.....
                      sombody plz help me!!!!
                      • #71
                        Well, we are not the game support (EA in this case).
                        Also you haven't said if you are using an image or original. Check the game with original disk and also check if you had installed latest patch of the game.
