I've got an AMD 64 X2 with NF4 mobo running XP. No probs installing DT4.00 or running any other protected games except starforce (SplinterCell:CT, King Kong, X3). I'll mount the image, click the exe, the disk check window appears, and 5 seconds later, instant reboot.
No freeze, no BSOD (yes it's enabled), and no memory dump occurs. IDE drives are manually unplugged. I've reinstalled both starforce and DT4.00, I've tried SFNightmare, SFCure + nightmare, 2000 compatibility exe's, and I've gotten X3 to work using Alcohol120 so the images are fine, I've tried all the typical solutions posted here...
I was sure it was a driver incompatibility, but I'm worried that I haven't seen others with the exact same problem. I've got no hardware conflicts that I can see. Help?
