1:1?
  • 1:1?
    hi im new so dont get mad.....
    the help area says i need a 1:1 ver.
    where can i find it?
    also the link to the manual does not work for me, is there anywhere else?
    o and i did find a link to 1:1 but it did not work
    thx
    Re: DAEMON Tools Help / Online Manual
    The link to 'DAEMON Tools Help' on the very left of the page under the 'Main Menu' heading is the same page as the online manual. You don't have to have a 1:1 copy if you create an image file on your hard drive. How did you create the image file you have already?
