st of you 've heard already about people who were able tot bypass StarForce with Starfuck. This is how it works for POP Two Thrones (POP3) and other games:
1. Mount the image in DT with all emulation options OFF and all other emulation software disabled as well.
2. Install
3. Launch the game and enter the cdkey, in the final screen you'll get an error that says "Insert the POP3 disc in another drive then press Retry".
4. Launch Starfuck 0.83b, select "StarForce 3.4.49.X" and then "CDs Deaktivieren", your opticals will be hidden. Now click "Retry" in the Error window.
If everything is fine the game will start, if you get the error message again, try if it works by clicking "CDs Deaktivieren" and "Retry" again.
If not, Exit, Unmount in Daemon tools, click "CDs Aktivieren" and then "CD Deaktivieren" mount and launch again.
For me this works fine, however most people keep getting the "Put the disc in another drive" message.
That's why we could help each other out and analyze the problem to see WHY it doesn't work for anybody. To see which conditions must be met first to make this whole thing work.
If it's the hardwareconfig like some people said, i'm using an ASUS A8N-E Nforce 4 Ultra mobo with 1 optical drive on the 2nd channel, 1 hd on the 1st channel and 1 on SATA
2. Install
