StarForce Nightmare Wont re-enable the drive
  • StarForce Nightmare Wont re-enable the drive
    I played SC:CT(backup) and used sfn and . After i finished playing, I clicked 'enable ch2' 'enable cd' and 'enable node' as instructed, but SFN won't show my DVD drive. I did the above steps again several times and restarted but no luck. Some help please ?
    And the Section Titles are bit confusing, so i hope this is the correct section
    Where is your optical drive?
    Primary master, secondary master, primary slave, or secondary slave?
    Enable whichever one, where ever your optical drive is located.
      try uninstalling your optical drives in device manager, reboot, and windows should reinstall them.
