Warcraft III
  • Warcraft III
    I have purchased the Warcraft III Reign of Chaos, and Frozen Throne cd's. I would like to make images out of them for my laptop, so that i do not waste battery life spinning the cd. I'd greatly appreciate it if somebody could please give me a detailed tutorial on this issue.
    Use Alcohol 120% to create that image.
    Please refer to the Alcohol 120% help file for information on how to create an image. If you still need help, please ask in their support forum.
    Edit: ...and read the Common Problems and Solutions! You don't need to double post, this forum is [U]moderated[/U]!
      I did not mean to make it seem as if i was double posting. In this thread i was asking what settings should i use to copy my original warcraft cd. In the other i was asking what emulation program/settings should i use to emulate the image.
        For mounting an image, you won't need any emulation, that's just for imperfect copies (on CD-R). Just mount the image in Daemon Tools, it should work with all emulations disabled.
