Splinter Cell Chaos Theory - HELP!!!
  • Splinter Cell Chaos Theory - HELP!!!
    Hy. First I want to say I`m new in all that so I would like some help in launching SCCT. Can someone explain it to me step by step how to install & play. I tried to disable dvd & node with SN and mounting image in daemon but it doesn`t work. I hope that my English isn`t so bad because I`m still learning :wink:
    HELP !!!!!!!!!!!!!!!!
    How did you create the image you're mounting in Daemon Tools?
      search the forums before you post
      you have to make an image with the correct settings ( DPM high )
      you have to disable drives in the correct order
      you have to mount from that image
      it works for me and many others
      Imperial Glory? or Metric Dishonour?
        I have downloaded it (38k image) and tried everything.
          Hi Helligen
          I propose you take your Game CD/DVD, use Alcohol and make the image on your own. This should work then out.
          Regarding the downloading: Have a look to the board rules.
            similar problem
            Hello, I too have had problems using Splinter Cell Chaos Theory. I have installed the game alright using Daemon Tools to mount the image. The problem is that to enter the CD key you have to have the DVD in the primary drive which isnt where it was mounted. Do you guys have any method of making my computer believe the mounted drive is actually my real DVD rom with the Splinter Cell DVD in it.
            Thanks guys
