I'm trying to play my backup (1:1 image) of Trackmania Sunrise (+eXtreme addon). As everyone knows the game uses StarForce 3.6 (with the addon).
My setup:
Mobo: Nforce4
DVDRW: IDE
HD: SATA II
DT4
I have read through the forums and have learned that those with Nforce3/4 based motherboards may be able to play without unplugging drives. After reading this, I tried loading the image with DT4 and launched the game -- FAILED. I then tried disabling my DVDRW and its IDE channel via Device Manager -- FAILED. (Also tried turning on/off emu options in DT to no avail) Lastly, I unplugged my DVDRW and had 100% success playing the image.
I am assuming I was not able to play (without unplugging) because I am NOT using the Nvidia IDE drivers. I would prefer not to use these drivers and am not sure they would help anyway because I have a SATA HD. I have read that DT4 has issues and causes reboots (when the image is being checked) when using an "Nforce+SATA HD" setup. So far I have had no reboots, and I am thinking this is because I am NOT using the Nvidia drivers. Does an "Nforce-based setup" imply that the Nvidia IDE drivers are being used?
In short, has anyone had any luck playing this or any SF3.6 game using a similar setup (Nforce4+SATA HD+MS IDE drivers) (without unplugging)?
Sorry if this post is hard to follow.
Thanks for any feedback!
My setup:
Mobo: Nforce4
DVDRW: IDE
HD: SATA II
DT4
