Sorry, I don't really know too much about Starforce, but will this work?
I have 2 HDDs on my Primary IDE and 2 optical drives on my Secondary IDE.
If I go into Device Manager and completely disable my Secondary IDE, will that work? Then, if the drives are disabled, I can unplug them without rebooting right?
Then after I play, plug them in and the enable Secondary IDE again.
Will this work?
If not, could you please explain why so that I can understand Starforce better?
Thanks!
Will this work?
Thanks!
I am planning to buy one!
