Operating System: Windows XP SP1, US-Version
Burning Software: ???
Anti-virus Software: McAfee VirusScan 8.0
DAEMON Tools Version: 4.0
I installed Rome total war fine, mounted the image fine, and when i go try to play it, it tells me to insert the correct cd and retry. What should I do? it installed and goes to the startup screen fine, buy when i click play, it tells me to insert the right cd.
thanks
thanks
its the only possibility i can imagine, rome total was is not well-protected....
