How do you know what DataType to pick when you make an image? Like Hitman 2 on the game database it says use SecuRom v4.83.11.0026, but what one do I pick Securom, Securom *NEW, or Securom *NEW(4.x/5.x)? And when I try to play it on Daemon Tools should I turn on Emulation Securom?
About Securom when making Image n playing it
You can use Aray-Scanner to scan the copyprotection or have a look into a Database. Then choose the profile of Alcohol which corresponds to the protection. Alcohol has no profiles for reading a dvd image, there you've to choose it manually.
For Securom 5/7: enable dpm, high precision and a low speed
for safedisc 4: you can enable skip read error's but it isn't really required, when you get read errors, clean the disc
Starforce 3:dpm option must be enabled like at Securom 7
That means, use the Securom new 4.x/5.x profile for your Securom game.Last edited by AnalCobra; 22.12.2005, 23:51.
