hi,
i'm trying to install battlefield 1942 from a bin file (using a cue file);
but when installing (at 39%) it gives the following error:" specified component cannot be found in the media. an attempt was made to acess a component that does not exist in the anmed media." and then installation is aborted.
i've mounted the image with d-tools 3.32, alcohol 120, burned it using alcohol 120, converted the bin file to an iso file and burned it using nero (also mounted the iso file with d-tools and alcohol 120) and i always get the same error. is my .bin file corrupted or am i doing something wrong?
thanks,
thanks,
