Hi all,
I looked over the internet for long while, searching on how to run Worms 4 Mayhem, and they all say the samething, that I have to use DT4, SFN, SFCURE, and basically I have to open the "box" and remove any cables for the CD and DVD ROMs...
I tried using DT4 and it didn't do any difference at all, tried everything, except removing the cables for the CD and DVD ROMs, and nothing worked at all...
What should I do?
Thanks in advance...
What should I do?
