for all you guys who can get the game to run but it crashes a lot back to the desktop I have found the solution.
It is because the game cannot handle dual core processors as seem to be the problem at least with me.
So once you get the game going and it stays quicky press alt+tab
Then ctrl+alt+delete go to processes tab and right click the battlefront 2 process right click it and select affinity and uncheck one core ... i unchecked core 0 and it worked like a charm.... it's just a hassle to get it to acutally start in the begining but once you do that your in business.
Usually if you restart your computer it will load :]
Lemme know if it helps you guys out.
