Hello, i have been registered for a few weeks but this is my first post.
In order to play POP 2T i had to unplug my optical drives and install sf cure and sf nightmare. However 2 or 3 times a day my pc shuts down by itself
. This hasn't happened to me prior to installing POP 2T and it only happens when the optical drives are unplugged.
When this happens the pc won't start unless i unplug the power plug and plug it again. I'm sure i have no viruses on the pc and other than that i have no problems. Does anybody know if this issue is starforce
related?
. This hasn't happened to me prior to installing POP 2T and it only happens when the optical drives are unplugged.When this happens the pc won't start unless i unplug the power plug and plug it again. I'm sure i have no viruses on the pc and other than that i have no problems. Does anybody know if this issue is starforce
related?
)....anyways you don't need them since unplugging the drives is enough. Starforce obviously can't detect something that's physically not there.
