i done all the steps but after this i will not be able to play pop3
1.intsall the game with damen 4
2.after installation system reboot and unplug the dvd rom both wire ide and power cable.
3.use mount image and start the game and enter serial no after all this step it will generate error pop3 disk inserted in an other drive .
my system specification is completet to play this game.
is there another method tell me step by step plz
and i can't understand if i unplug the dvd cable and then diable all ide cannels is that possible i can install the game.
is there any software which i can dowanload tell me the link.
step by step plz
clear i will waiting reply for help to run this game
thx
step by step plz
thx
