I just bought Brothers in Arms........When trying to install the game(which is DVD) it gives me an error message and wont even allow the setup to run. It says "program has failed to initialize." I made a copy on my hard drive via Blindwrite. I've been using daemon tools for quite a while now. I upgraded to version 4.0......disabled my ide drives(CD-RW and DVD-R)....the image mounts fine. I can see all the files. Setup goes into limbo no matter what I do. No error messages or anything. I have uninstalled all my burning software and daemon is the only thing I have installed. I even went and changed the virtual drive to drive D......I've enabled all the copy protection and still no dice. I am running XP Pro with service pack 1....This is the first time I've had a problem installing a game.......It might be my dvd drive since its a Dynex DX-DVDR100......but I should still be able to install the game once the image is created shouldn't I ????
Any help would be appreciated. I dont think I have a bad DVD since Blindwrite created the image.....
Any suggestions or help would be greatly appreciated.
