I posted this way on gamecopyworld too.I will be happy if somebody test it.for me it works perfectly.Here is the method:
My harddisk is SerialATA so i have only optical drives attached to my IDE controller.So to play starforce protected games i just disable my IDE controller in device manager ( The whole IDE controller not the optical drives ) , mount the image in daemon tools 4 and play.After playing i just enable again the IDE controller and my optical drives appear again.No need to restart.I tested this with Prince of persia T2T and in a few hours i will test it with X3 Reunion also.I will be very happy if somebody with sata harddrive can test this way with other starforce games.This trick works for X3 Reunion also.
I made a little research and a few experiments for the problem with PC freezing or rebooting during disk verification of starforce.Often this is caused by emulations and virtual device of alcohol 120%.To fix this it is needed first to uncheck all things in Emulation and Extra emulation in File->options menu of alcohol 120% and second disable the alcohol 120% virtual device by setting Number of virtual devices ( File -> options->Virtual device ) to 0.There is no need to uninstall alcohol 120% completely.
Best way so far. Thx!
