CureROM Update 1.2.2
  • #46
    Don't use the LAUNCHEAW. Use the "sweaw.exe" in one of the sub-directories. (I don't know the exact sub-dir, because I haven't installed it yet)..
    Then it should work.
    @Bobafart: The name of your image is very suspicious...
    • #47
      If you get the same error as I posted before I got it to work by mounting with DTv4.03 and using SecureROM v1.1. Works but still gives me an exception once and a while. Empire at War is patched to v1.02 also.
      • #48
        Sometimes it works, sometimes it doesn't.
        For example, It works, I shut the game down, click the same icon I made and it will say original disc not found.
        Why is that? Nothing has changed?!
        • #49
          I can not for the life of me get Crashday to work. I have done all the stuff that people have told me to do. Could someone please give me a detailed description of what to do? Thanks
          • #50
            We also need some more information from your side...
            Daemon-Tools version...
            What application(s) are you using to hide your virtual drive(s)?, CureROM or SecuROM Loader(aka AntiSecuROM)...
            Mail:
            curerom @ daemon-tools.cc
