When I load up bf1942 the spash screen comes up, then nothing happens.
The game loads up fine when I put the cds in my sisters computer, then load it up using starport and starwind (I do not have any IDE devices at all, everything IDE related is disabled in the BIOS. I'm currently using a SATA hdd)
I am 99% sure I burned the CD's correctly: using the latest version of alcohol I installed the the game on the other PC, played it once (with alcohol's emulation things enabled) then wrote a bin & cue file so it skipped the errors quickly.
Any ideas? - I also had the same problem with DT4.00.
