Hello everybody,
It is only since today that I'm a member.
I have a problem getting Rome: Total War or Imperial Glory to run correctly.
I mounted the files in Daemon, made Wizards using Alcohol 120% and burned the games on CD/DVD. After that I installed the games on my harddisk.
Even though I have the Daemon Emulator activated (Safedisk) the computer tells me with both games "to insert the correct DVD".
As far as I've understood the emulator is the tool to swing around the protection.
What am I doing wrong?
(I got the 4.03 version of Daemon)
Thanking You in advance,
Bart
Z a.k.a. "pik_met_haar"
Bart
