FADE copy protection?
  • FADE copy protection?
    i have v8 supercars and would like to b/up orig ,can it be done.i tri wth clone and used daemon to test but no go,no error mesage just searches hard dsk then nothing
    Download clonyxxl and check what protection it uses (possibly securom). Then download alcohol 120 and try making an image using securom 4.8x NEW datatype.
      clony xxl says its securom new,will let you know how i go afterwekend thanks
        It's securom 4.8x + fade.
          fade copy protection
          i managed a working b/up using alcahol 120% no dt required thanks guys
