When using deamon tools for some reason my sifnleplayer won't work but the multiplayer does any1 know how i can fix this?
COD2 help
Some games work without an original CD in multiplayer, although I doubt that'll be the case with CoD2. You might try if multiplayer works without CD though, just to be sure.
If that's the case, it's probably just a bad image. If not, we definitely need more information, as Underheaven already explained."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
CoD2 Singleplayer on DVD is Safedisk 4 protected - you will need SD4Hider. See my post on Alcohol 120% Forum for running the game with one-click - you will need Daemon Tools as well for this.Originally Posted by Shua_ZaneWhen using deamon tools for some reason my sifnleplayer won't work but the multiplayer does any1 know how i can fix this?
Richard
