Hi,
I've got a problem running a program after having installed it from an image and keeping the image mounted with Daemon Tools.
The program asks to insert the CD into the drive and after inserting it into the CD-Rom Drive it works fine.
Unfortunately I've got no option to specify the CD drive in the program...
Any idea? Thank you so much for your help!
Bastian
Bastian
