Hi.
I purchased Trackmania Sunrise and can play it from the CD just fine. I made an image of the game with Alcohol 120% using the Starforce v2/v3 profile, and I can use the image to install perfectly fine. I then upgraded Trackmania Sunrise to Extreme, which as I understand also upgrades the Starforce version to 3.6.
However, when I mount the image in Daemon Tools v4.03 (x86) and use Starforce Nightmare to disable ATA, the disc scanner sits there for about 5 minutes before producing the error "Failed to identify the disc in the drive. Insert a licensed disc.".
I have a Gigabyte NForce2 motherboard (GA-7N400Pro2) with my two WD2000JB hard drives running from the onboard RAID controller, and only a Pioneer DVR-110D on the onboard IDE, so disabling ATA in Starforce Nightmare has no effect on my hard drives, only the DVDRW.
Is there anything I am doing wrong? Even without upgrading Trackmania Sunrise, using a base install, it will not work.
