Enter the matrix blacklisted?
  • Enter the matrix blacklisted?
    play disc is Securom 4.84.75.0045
    fails with DT v3.33
    However RMPS works with Alcohol 1.4.2.308.
    Looks like DT really gets on publishers nerves (so sad)
    Thx, we investigate it soon, thank you for your report, we appreciate every help
      Enter The Matrix worked fine with Daemon Tools 3.32
      It also worked when patched to 1.52
      This updated Securom to 4.84.76.0062
      I will test with new 3.33 tonight.
      Just tested with 3.33 and it still runs fine.
      Cheers
        Cheers
        I confirm!
        Tschau
        Viper Zx
          After seeing your replies I tried again and it works. I can't explain what happended first time around. Maybe I should have rebooted and tried again before??
            I'm having the same problem with the same versions. I have used disk dump with all the different options to try to get a play disk that works. The install was done off of the image'd CDs but it refuses to play with anything other than the original CD in the physical drive. I have also tried enabling the securerom emulation in Dtools.
            Oh well--- I'll keep trying.
              You can't use discdump for securom. Try using alcohol instead.
