Hey guys. I had to reformat my old computer like a week ago. I was using a later version of Daemon Tools to play Frozen Throne. When I reinstalled my new computer, I got the new version of Daemon Tools. I mounted Diablo 2: Lord of Destruction and Frozen Throne. Diablo 2 worked perfectly, no worries. When i tryed to use Frozen Throne, it would keep asking me for the cd. It never lets me play. I also found out some information if this can help anyone solve my problem. The Daemon Tools Version I am using is DAEMON Tools 4.0.3 X86. I dont remember the Daemon Tools I was using before I reformatted my computer. Also
this is some more information about the Games (CDs are the image files that I used to mount on Daemon Tools):
Diablo 2 CD:
[00:23:49 AM] SecuROM detected -> K:\EXPANSION [133EEBA0]
Diablo 2 Installation Files:
[00:24:40 AM] SecuROM 5.03.13.0190 detected -> I:\Program Files\Diablo II\Game.exe
Frozen Throne CD:
[00:25:09 AM] No Protection detected -> J:\TheFrozenThrone [96302F58]
Frozen Throne Installation Files:
[00:25:51 AM] SecuROM 4.84.76.7966 detected -> I:\Program Files\Warcraft III\War3.exe
[00:25:52 AM] SecuROM 4.84.76.7968 detected -> I:\Program Files\Warcraft III\WorldEdit.exe
What should I do to fix this problem?
Also, in the mounting, Frozen Throne is first, then Diablo 2. I have Safedisc and Securom loaded, with all the Options.
Any help will be gladly appreciated. Thanks!
Diablo 2 CD:
Frozen Throne CD:
