help with halo
  • help with halo
    i made a copy of it and turned on safe disk emulation and it still says i have to put the correct disk in
    You will not need emulations for images, those toggles are only for copies on CD-R.
    How did you create that image? You'll need to create it with Alcohol 120% using the right profile.
