Well after reading and trying pretty much every option to make this work properly, I have found a solution for my setup.
First off, all I used was Alcohol 120%, and CureROM. Second, my error was both "emulator detected" when not using CureROM or SecuRom. I also got "cannot be found or authenticated" when I did used SecuRom and CureROM. I tried every single option, the crazy xcopy (which doesn't do anything at all) disabling drives etc. I did, however, get it to run once, but only once. I based my information I collected on what most of the experianced posters were saying.
The problem mainly consists to your actual image. I made 10 different images and tried about 20 times before posting this You must make the image on precision and on a slower speed ( I used 8x) I made 5 with 8x all worked, I made 5 others at maximum, only one worked and only worked once.
When you use CureROM, follow these steps as well:
1. Create a New profile ( do not use an older profile to make sure of a clean slate)
2. Click the application "sweaw.exe" NOT the launcher.
3. Find your image
4. Select to run with Alc120 ( I will also run with DT but I only tried that once)
5. Suspend the autorun
6. You can set it to wait 7 or 10 seconds but I not think it will make a difference.
Once the icon is made change it's compatability to Windows 2000. ( I did this as a precaution since it did work for alot of people but I did not try without it)
Hopefully this helps anyone with their problem with Empire at War.
SkRiGeR
3. Find your image
SkRiGeR
